Just added two new nodes , screen comp which does analog and digital, various effects that define that category and a glow / glint / glare node that takes a metric z depth for realism. I tried to keep these as true to camera and lenses as possible so that was my goal.
I do want to caveat that I built these OFX heavily dependent on python and the hooks that it needs is in 27.2 , so if you want the best workflow make sure this is the version you are running. I tried this because the limitations on OFX and now it becomes clear why every manufacturer has a pop up app that functions outside of flame to give them more control but I honestly never liked that so I am trying to keep them inside of flame as much as possible.
Did a nice update on Face UV , Motion Vectors , upscale, and elements. For face UV is probably the biggest with much improved tracking and painted frame ability to carry the fix without unwarping and also morph between frames. Upscale has the new LTX Decompression (macroblocking, banding, ringing), Restore (archive footage — resolution, casts, flicker, dirt; colours from a short scene description) and Refine Details. Elements now has LTX water that can be added.
Just published an Extend Native which will fill from black edges , you can also feed it a painted frame and use some of that as well, or feed it a matte. It works surprisingly well.
very cool and much appreciated. going to take a look now
Looking forward to trying this
let me know what you all find I was playing with it a bit and seems to work fairly well but I was short on time. Funny what it fails on I shrunk a room down 20% and it rebuilt a lampshade to be correct but freaked out on the molding, but the rest of the room was pretty darn close.
Any docs regarding using this ofx?
Point your LLM to his github and just ask it to give you use cases and how to put them to work.
