Problems creating users in a trial
Hello everyone,
I’m on a mission to run a trial for a test on a Macbook, and before I could even run any performance tests it’s created issues and displayed errors as if users already existed on this machine. Can anybody identify with such messages as seen in the errors attached below?
Cheers,
Alaz
this is probably the first thing you tried, but did you add a “2” after your name, or use any other name? User profiles are independent of versions (sometimes?) so when I run into this issue I just make one called “Andy2” and it works.
if that’s not the solution, i’ve got nothing.
Hi Andy,
I’ll call this one murphy’s law as usual. Usernames didn’t exist earlier but a different one did work eventually as advised. I allowed permissions for folders coincidentally, but suspect it’s not relevant for the username creation. Thanks a million anyways!
Cheers,
Alaz
