QT Format preset
Is there a way to export a QT format preset?
Ideally I’d like to set this for export in batch…
Batch QuickTime export?
That’s a two stage process
Ideally, yes, but currently you need to export from the reels, so I’d like to save my QT export preset in a know location
Paul
This will take you approximately 11 minutes on a large language model.
You’ll be done before the digestive biscuit dissolves in your tea.
Time to pop my claude cherry!
Not sure if you’re talking about the xml export presets in /opt/Autodesk/shared/export/presets/ or something else
No, this is for bespoke presets that we create
Creating the set-up and saving it as a preset shouldn’t be an issue. Getting it to run from batch seems to me to be more of an issue.
It’s more about the ease, or lack of, to share with other artists
If it isn’t one of the many presets that come with the system, then there are multiple files that need to be installed on local machines. Most of the instructions in an export preset are pointers to hidden files.
