I’m trying to cover some side boob on a series of shots with the actress dancing in a sequin dress at a disco club with a lot of flashing lights. Stretching the top just a couple of inches seems like the best way to get this done. I have not really done many slimming shots or ever even used the distort node. I’m trying to figure out if there’s a way to roto the blouse in mocha and then use that shape back in flame to animate some of the tangents to pull and extend the blouse over where needed? Last night I dreamed that the tangents of the gmask shape could be manipulated like verticies … but then this morning I woke up, … I haven’t yet found that magic button.
Any links to tutorials or videos on how to best conquer this type of task, or guidance to that magic button, would be very much appreciated!
I would roto the blouse then do manual UV vertices key frames using move u vertex either using perspective or bucubic. Set those key frames to line up to the line of the dress or where the blouse edge is etc. Then switch enable the edit track option on the surface to then manually pull up to where it works for covering. Key framing again but will be cleaner cause the points you are moving from are the initial UV vertices that you matched to the edges of the blouse
Pretty much covered in this guy bar the key framing after the fact
Good luck with it, don’t be afraid to start over too, when doing this route it can be a bit cumbersome. Again if u have something working id duplicate hide it then tweak so you can always go back to what was working etc
Haha, my internal Beavis was doing the same thing when I wrote it - figured it’d get more attention.
Shout out to you Sinan and Logik Live #148! Really appreciate your tutorials and also to Bryan Bayley for Logik Live #74, seeing extended bicubics and UVs used in varying ways is beyond helpful, very much appreciated!
Thank you space_monkey, I’ll give the Motion Vector OFX a shot, less roto would be great
