Small backups of Flame working files
and did it work?
so is it enough to back it up or do i need to backup my whole project server VM
Point /opt/Autodesk to ZFS and snapshot regularly.
Many times. Archives are preferred, but if the data is there, there is a possibility to get back up.
with the INSTALL_PROJECTSERVER script there is now a --dataroot switch which makes it even easier to slice off only your relevant data onto a separate location so the OS drive becomes rather generic instead of “pray something doesn’t go wrong” paradigm of the past.
The only things I have ever used from opt/Autodesk when rebuilding the system is my personal material, such as hotkeys, bookmarks, python scripts and fonts. I keep that all saved off separately and update now and then as I add things. Everything else that is project related is part of the archive.
Step 3 shows you what files are useful to have saved.
so all in all whats really missing is a way to backup working files while everything is running due to the nature of swdb beign a database.
In postgres you can basically export snapshots of the database while everything is running, which is neat.
having the projectserver on a vm like alan is doing will bypass that problem.
I am trying to protect against hardware failure and with multiple flames connected to one projectserver loosing a whole day because i only back up at night because i need to stop sw is not that great.
Setup a multi node Proxmox cluster with CEPH and live High Availability migration.
Or buy 1 quality Dell server and LXC live backup to Proxmox Backup Server at interval of your choice. We do every 4 hours.
I’ve never had an issue with a Dell server and in USA, they are plentiful on eBay for cheap price in great condition.
Exactly this.
Live migration is fascinating.
Hard on mac hardware. (in my limited experiments)
Quite straightforward elsewhere.
And Ceph ftw.
