Alexa metadata
Hi guys,
I have a clip which shows this info. Do I assume the lens is 25mm or 250mm
Also what does the camera distance number mean
25mm and focus distance. You can also use the ARRI’s metadata extractor to get frame-by-frame metadata if it’s a lens that supports LDS or they set the remote focus controller up correctly.
WOW Thant’s interesting. Thanks for the info.
