Dpx pixel aspect ratio after import
Hi all,
is it possible to change the pixel aspect ratio of dpx files after import from the format editor?
Gareth Parry
Yes. What do you have now and what would you like it to be?
Hi @randy - I want to switch between square pixel and anamorphic pixels (1:2).
Play with the Ratio by either doubling or halving what’s in there. Don’t forget to make sure that the Use Ratio button is turned on in Viewing Settings.
Sorry for the late reply @randy, but could you clarify where the ratio is accessible in format options from the timeline?
Format Options, Resize tab, under Destination is a Ratio numeric field…its probably set to “Set to 16:9” or “Set to w:h” right now."
