hi all. is there a way of having a horizontal two up? im using an Apple XDR which isnt that wide and working on 2.35 material. would be great to have the F4 on the top split and the batch schematic on the bottom split
I think the closest you can get is the 3-up split. You’ll get one native wide; the other two panels split vertically, I guess you could just resize to make one of them as small as possible (which is only about a node-width wide)
ah yes of course you can reposition the split! thanks that will do for now
