So the results out of Sammieroto using the matte alpha not the segmentation matte would be the same as if you used matteanyone? is sammieroto using matteanyone 2 yet?
Correct, sammie 2 isnāt even out yet officially and the person behind sammi would probably need time to implement into Sammie.
Makes a lot of sense, thanks, @Zarxrax !
Are you planning on integrating matAnyone2?
Sammie-roto is so much better than straight matAnyone in comfyui ā¦
When I was asked to try in comfyui, all the shots had the person not in frame at the beginning and end of the shots ā¦
It looks (from the video above) that there might be better temporal stability in semi transparent areas (hairs ā¦)?
@Bryanrosenblum Itās brand new and unreleased, but the plan (per @Zarxrax on discord) is to try to implement it. Seems more likely to work than SAM3, but itās all speculation.
MatAnyone2 is not released yet, but when it is, I will definitely be looking at implementing it into Sammie-Roto. Just donāt expect it immediately, as it will probably take me some time.
Regarding SAM3, I am currently not planning to support it, because the results from testing with point prompts was not promising. The key feature of SAM3 is just being able to segment with text prompts, and I donāt really see that as a useful feature for Sammie-Roto.
Installation instructions for Sammie Roto 2 on ADSK Rocky 9.3 with DKU 20.2.1 and RTX 6000 Pro Blackwell / Cuda 12.8.
## Sammie Roto 2 installation
# Update and install Python 3.11 and development headers
sudo dnf install python3.11 python3.11-devel -y
# Install dependencies for OpenCV, Qt, and Video processing
sudo dnf install mesa-libGL mesa-libGL-devel libX11-devel ffmpeg -y
mkdir -p /scratch/workspace/GitHub
cd /scratch/workspace/GitHub
git clone https://github.com/Zarxrax/Sammie-Roto-2.git
cd Sammie-Roto-2
/usr/bin/python3.11 -m venv venv
# Activate your new environment
source venv/bin/activate
# Upgrade pip inside the venv
pip install --upgrade pip
# Use the provided script but force it to use your active environment
# We do this by temporarily aliasing 'python3' to your venv's python
alias python3=python
bash install_dependencies.sh
sudo dnf install xcb-util-cursor -y
cd /scratch/workspace/GitHub/Sammie-Roto-2
python sammie_main.py
Hi @wiltonmts thanks for this. The script is not available anymore, can you have a look ?
Thank you !
Hey @Jerem , I took a look and it turns out I accidentally removed that file while organizing some things on my google drive ā Iāve just put it back up. Recently, I made a nice update to this script to work as a file scan system to improve the round-trip of results from Sammie and other matte exports. If you want to grab the updated version, hereās the file:
https://drive.google.com/file/d/1MaI1_6doysXVM0oK305NZK57q6Wqd1di/view?usp=drive_link
Main updates on SammieRoto RoundTrip:
ā Path history and more token options in Settings ā save and quickly switch between configurations for different projects, with standardized paths using Flameās native tokens
ā Smart Import ā scans the result folder, shows info for each file and lets you choose what to import
ā Group Mattes ā automatically chains mattes through Comp nodes with your chosen blend mode
ā Multiple Groups with Compass ā create several independent matte groups in the same Batch, each visually organized in its own Compass in the schematic
ā Persistent Groups ā close and reopen the dialog, groups are still there. Add new mattes without rebuilding anything
As a bonus, thereās also another file included which is a matchbox shader I made and have been testing ā itās pretty cool (a version similar to JB_ocean).
Tested and working 100%. Really great job.
For Anyone interested.
MatAnyone 2 just released.
You can try and use it on SammieRoto by just downloading the model and replace it at the checkpoints folder and rename it as MatAnyone.pth (not MatAnyone2.pth) as the original code from SammyRoto is looking for MatAnyone.pth file.
Just did a comparison with these two models using this method, and tested with a horse shot and the result is dramatically improved. Way better.
Hi,
i have been following the install suggestions but getting stuck on the python version. Ive used Venv and Anaconda but when i try the bash install_dependencies.sh it doesnt see my later versions of Python installed.
i have python 3.11 installed but following @randy install instructions using alias python3=python
(venv) [tmaniatis@vxfhost Sammie-Roto-2]$ bash install_dependencies.sh
Python 3.10 or higher is required. Detected version: 3.6
Why is it only looking at my system Python version on 3.6 and not the higher 3.11 or 3.13 i have
[tmaniatis@vxfhost Sammie-Roto-2]$ /usr/bin/python3.11 -m venv venv
[tmaniatis@vxfhost Sammie-Roto-2]$ source venv/bin/activate
When i use Anaconda i dont get this error but i get a CV2 module missing and cant seem to install that by: pip install opencv-python
so i get stuck there also.
i have activated the 3.11 in venv so now im a little lost here on how to fix. Im on rocky 8.7
both methods for me is failing currently, anyone have an insight orshould i install a later version of Rocky here?
Theo
to follow up and close out my issues, after 3 days of trying to install Sammiroto including getting an AI agent to help problem solve, just install Sammiroto 2 instead. it worked in 3 minutes flat.
How would you rate this against Flameās Automatte in 2026.?
Lately, Iāve been working on some possible updates to contribute to the SammieRoto project, and I just submitted them to Zarxraxās original repository for review. One of the additions is the VideoMaMa model; although itās heavier than MatAnyone 2, it offers better temporal consistency. I also added the Corridor Key model, which runs on smaller GPUsāI used a pipeline that runs on approximately 8GB of VRAM. I havenāt had the time to test it extensively or with very high resolutions yet, but itās been running well on my end.
Here is the link to the pull request I made:
https://github.com/Zarxrax/Sammie-Roto-2/issues/42
@wiltonmts - itās like one of those jurassic something movies: itās all quiet while youāre taking a leak and then the trees explode and there are giant monsters all around!. Good work brother.
Thatās a great addition @wiltonmts! Out of curiosity, does your implementation of Corridor Key include MLX support for MacOS like this one does?
Having access to these models/approaches in their own little environment is super handy but Iām starting to wonder if itās better to keep models in a single location and then link to them within each environment. Having the VideoMaMa which weighs in at ~37GB in 3 different places, for example, starts feeling a bit silly. I suppose the answer would be to just do everything in Comfy but that takes away the easy of these stand alone approaches.
Iāve been working on an MLX port. My thought was to go Pybox. Itās āfairlyā performant.. 3sec/frame at 2k on an M4 Max.
Hey @kyleobley, good point!
I ended up tweaking the scripts just for my Linux environment and didnāt get around to Mac adjustments, which is exactly why I made a pull request to the official repo so they can review and make the necessary tweaks for other platforms like Windows and Mac.
I can take a look at the EZ-CorridorKey pipeline and suggest MLX support, though I donāt have a Mac here to test it.
On the model downloading question, itās definitely relevant but also depends on each userās pipeline ā good point to keep in mind.
The VideoMaMa version Iām using is around 19 GB because I use āallow_patternsā to avoid downloading extra unnecessary files from the repo.
Hi everyone,
Is there a way to use a custom mask with Sammie-Roto for object removal?
Sometimes the internally generated alpha doesnāt isolate the object I want to remove. It would be great to be able to feed a custom matte or mask to guide the erase.
Any workaround for this?
Thanks!
100% this makes a lot of sense.
Duplicated models on flame production machines is quite ugly. For Comfy we use server centralized (maintained) collections and it seems perfectly fine and fast. An option in sammie-roto would be great Alan @Zarxrax!
Btw Alan, out of about 30+ in house flame hooks, Sammie-roto was the most used in the last 2 weeks or so on our 20 ish flames. ![]()
Are you planning on implementing MatAnyone v2 soon? No pressure man ![]()
