Original video on Fluid Morphs?
I have another version that might work better, but I never road tested that one very much either because I never change my start frame. I’ll try and dig it out and throw it on the portal. I’ll probably take the current one down.
Untested_SF.zip (96.1 KB)
This one may work better. Also , I think @john-geehreng may have cobbled together a version that works with a batch start frame other than 1. The previous version works fine if you don’t change the batch start frame.
Amazing! It works! Thanks sooooo much!!!
When loading the setup, it asked if you want to Keep or Align the start frame. I selected Keep. In the FluidMorph Control node enter the start frame to match the Batch start frame–and you’re good-to-go!
