Why oh Why isn’t the pattern browsing option in the export tab as well as import!
I must be missing something…how could it?
I agree, there should be a way to turn it off when browsing in the Export tab!
if you set it to show frames in import, then when you export all you see is frames and the only way to switch to sequence browsing is to go back to import and change it. its a pain
Ah. I misread your post.
