Write node
Seems cool to have this in Flame :fire:
What say??
Check out the Reveal Path script on the Logik Portal. It will let right click on any clip in Flame that has a path and open the path in either a Finder window or the MediaHub
Also check out the Clip Path to Clipboard script.
Mike
That’s great to know @MikeV, But would be great if we can reveal the path by right clinking on write node. As there is no option to get the rendering path of write node straight forward rather than going through mediahub manually after you finish the render…
Sorry… should have added that you can right click on a write node and open the path in a finder or the mediahub with the Reveal Path script. Although only certain write node tokens are supported when translating the write node path.
Mike
That’s okay @MikeV, Is it still possible to update that python script?? That will be very helpful…
