Hi - I’m seeing the artefact above on the first frame of a stabilise using 2D Transform. I have seen them on the edge before, but never in the image itself.
Have other people seen this issue?
I’m on 2021.0.0.264
Thanks,
Gareth Parry
Hi @GParry
I would advise updating to 2021.2.1 and see if this issue has been fixed in the current release.
Thanks
Grant
Yes I have seen this before. Often with a time-warp. We might be getting different things but if they are the same, check the alpha output. You should see the same error on a solid white frame. Use this with pixelspread interpolate for a quick fix.
It hasn’t been fixed. I just repo it up 101 scale to rid it of errors.
