ACES Reference Files
Have any of you downloaded the ACES ref files from the Academy. When I put the correct transform on it it looks nothing like the image I see in the browser. Display is correctly showing ACES CG or just plain ACES if I add it on import.
Not 100% sure if the answer is in here but check out @randy ‘a 8 minute ACES:
What qualifies as the “correct transform”? What color viewing rules do you have set up? I ask because flame’s default “legacy” color is the “wrong answers only” of color policies and can have a lot of follow-on effects.
Thanks Andy Milkis, Of course that did the trick.
That’d be a great Phil Collins 80’s cover band name… “Wrong Answers Only.”
