Any AI model as an OpenFX in Flame: iNodes.ai
I’ve had the pleasure to collaborate with iNodes.ai (alpha/beta stages) for a few months, mostly on the Linux studio version.
Been great to be able to connect them and our dear ADSK Flame dev team, since it seemed to make a lot of sense.
Has anyone seen a presentation at IBC?
You’ll see what iNodes is from the link, so I’ll be brief and specific.
On every job I’ve been involved in that needed some AI steps, there were several back and forth stages between AI tools (Weavy mostly, beeble, runway, photoshop, topaz …) and comp apps (Flame, Nuke).
Keeping track of the whole process, and the time spent between multiple apps and artists is hard to manage, lots of disruption in the flows. Also chances are that you won’t remember what the needed steps are when you want to do a revision a month later.
This iNodes concept happens to solve all of these problems, in my experience.
The OFX nodes let you run any commercial and/or open source model inside your setup/batchgroup/flowgraph.
Successfully benchmarked against Figma-Weavy for same deliverable results.
You can use about 900 models (credit based), and any comfyUI workflow, (free generations), with Comfy running either locally, on a server, or cloud based.
Comfy workflows are simply available from the OFX presets giving exposed setting controls … jaw dropping imho.
It’s also available in blender, Houdini, Resolve and Nuke. Mac, Windows, Linux.
I’m not financially linked in any way with the project, I simply strongly support it and think it’s worth sharing.
If you’re interested in giving it a try (Early bird option?), they kindly gave us a promo code.
For info, using the code also helps keeping track of how and where the words are spreading from, for example.
If you’re interested in the Linux (studio) version, also make sure to mention the code.
Promo Code: LOGIK2610
Hope you’ll enjoy this as much as some of us already do.
Direct contact: contact@inodes.ai
Very cool.
We got a demo of iNodes at IBC where the Flame team was showing it at the Dell booth. I’ve since installed the studio version and experimented with it. The ability to run that many cloud models on enterprise T&C inside your batch is indeed a very welcome workflow, and can benefit Flame artists in numerous ways. And that the same OFX works in several other apps makes this an easy adoption whether you just use Flame or a bigger pipeline.
In my experience, the install is a lot more complicated than your average OFX. And there are some issues in their workflow that could use some improvement, and which I’ve discussed with them. They’re very responsive and I would expect this to evolve rapidly.
I would summarize my experience - this is a stable but early stage product. And it works best for a somewhat settled pipeline / model selection. It’s when things are fluid, or you are constantly building your own ComfyUI workflows that can also run as a node, that things get a bit bumpy.
But definitely worth experimenting with.
They will be competing with the fact that everyone just rolls their own OFX these days over the lunch break. So it might come down to which API and plan you prefer the most ot access the cloud models.
I also installed the demo version on Linux. Install was a bit bumpy as Jan said. At the end, he helped me out ironing out some final kinks in the process. I am a single Flame artist not that versed in ComfyUI yet, so the ability to access models from within Flame was liberating. But again I haven’t had the time to dive into it full-time.
You people are churning out OFXs like crazy, it’s hard trying to keep up with you all.
do i have to have my comfy ui setup running or linked? I use comfy ui on windows portable locally - and flame on linux usually. do i need a build of comfy ui on my linux box or does it pull nodes from the cloud or their own servers?
You need to have comfy running anywhere your running Flame has access to. You just give Inode the URL to connect to.
Could be local, another machine, server/cluster, cloud …
You export your comfy workflows as API and App, load both in inodes that will ‘convert’ and store them. They become available in the OFX menu.
From there you have control on the parameters you exposed in the comfy app.
Once ingested in inodes, you don’t need your original workflows for Flame work. (But do archive them :))
Nice Sinan!
Good point about the many quickly vibe coded projects popping up lately. Lots of OFX, apps … many free, supported/maintained or not.
I’ve personally chosen to give inodes more time and attention because it’s been cooking for long enough, made by dedicated professionals programmers, cross apps and platforms, well maintained, quickly improving, and made to last.
Web apps like weavy or cineflux (+ beebles, runway, etc.) are cool, but this fills gaps big time.
We should let Benjamin talk here. He’s the founder of iNodes.ai. @randy
Oh yeah 1000%. Sorry our spam filter gets spicy.
Benjamin we always welcome hungry tigers.
I’ve okayed your post but me thinks you also deleted.
Please resubmit.
It’s my party you can post if you want to. And you should!
@Benjamin.C
Hello everyone,
I’m Benjamin Cavillac, founder of iNodes. I just joined the forum, and since you’ve been talking about us so kindly, I wanted to come and say hello myself. Thank you Stefan for the introduction, and thank you Jan and Sinan for your feedback, including the bumpy parts, because that’s what helps us most.
Blakieman, yes, you can absolutely do that. iNodes talks to ComfyUI over the network, so your Windows machine can stay as it is and work with Flame on your Linux box. Just start ComfyUI with --listen and give its address to iNodes. And if you don’t feel like using ComfyUI at all, the cloud models work without it.
Jan and Sinan are right about the Linux install, it still asks for some IT comfort. It’s completely doable for a freelancer though, and we’re working on something much simpler for early next year. For now Linux is on demand, so just write to us at contact@inodes.ai and we’ll help you get it running.
On our side, things are moving well. We released version 1.1 at the start of this month, so you can now preview your generations directly in the node, and it’s compatible with OpenClip and ComfyUI too.
Jan is right that anyone can roll their own OFX over a lunch break these days. What we want to do differently is talk directly with the people who make the software. We’re in discussion with Autodesk and other software makers, because that’s how you really understand the constraints of each application and how to integrate with it properly. It takes more time, but it’s the only way I know to build something really well integrated.
We’re also trying to set up a partnership with Ranch Computing to offer machines for custom ComfyUI setups, but that one is still in the pipeline.
I come from 3D and compositing myself, so meeting some of you at IBC meant a lot.
To thank this community, and for anyone who missed the Early Bird, the code EARLYBIRD2026 still works until the end of November (all the Ultra models for €7 a month instead of €80).
For now I’m mostly here to answer your questions.
Thanks for the warm welcome,
Benjamin
@ALan will probably complain but that’s normal
Thanks @randy
In the future, I will try to only complain about things like this:
Jim Carrey's Ace Ventura: Good Call!
@ALan
Just an example of when you feel like throwing your Screen in the trash!
We’ve just tested iNodes and Flare with a Parisian studio, and it seems to be working really well!
Hi
I’ve just started exploring iNodes, and I’m looking for some tutorials on how to do a few things, like referencing clips and motion control. Are there any tutorials around that lean towards using it in Flame?
Hey @johnag! Inodes is an OFX, there’s nothing really specific to flame in using the models it provides. You already know flame and it’s a ‘simple’ plugin.
I’m under the impression that what you are looking for is more about how to chose and articulate models to achieve specific tasks. You can learn that from Figma Weavy tutorials for example.
Very often, you’ll find yourself starting with still frames (cheap) as a starting point, of refs, then maybe generating design sheets, then using it all to generate or modify videos.
Have you been experimenting with iNodes since you posted?
Anyway, happy learning!
Hi, yes, I have been playing around with iNodes. The only thing I’m a bit confused about is how the inputs work, like how do you do motion reference video with multiple reference frames in SeeDance?
