Some would expect 1-1-1, others 1-2-1
Fewer and fewer of our clients are coming into the suite for post with one exception. Colour grade.
Having all of the decision makers in the same room looking at the same calibrated monitor is the best way to judge a grade.
Even if we were only focusing on broadcast, you have a vast range of different televisions all made by different manufacturers and all set up by the average people.
But we are not just talking about broadcasting television anymore. We are sending review quickTimes to clients and uploading to social media and streaming services.
I’m sure you read all this
already so I’ll not repeat.
What you want to do is try and control as much as you can. You want your remote client to see the skin tones correctly so that they can sign it off but once it goes out into the world there will be people who see it differently. Your client might catch it on another device via YouTube and won’t like the results.
Yes it sucks. It is very unsatisfying.
Have you tried sending the client QuickTimes with colourSync turned on so that you get a rec.709 with a 2.4 gamma (1-2-1)? This often results in a darker QuickTime than just the standard (1-1-1) but only when viewed using QuickTime on a Mac using ColourSync (because is is colour management).
The Blackmagic streaming sounds like it is working. Have you tried a service like ClearView or Louper for Flame?
These have worked for me in the past but it still depends on the viewing conditions at their end.
For a job recently we ended up creating two grades. One for the broadcast and a slightly darker version for the online.
what is the file type of the files that you are importing into flame?
what is the color space of the files going into your project?
how is flame managing those files?
how is your color policy managing those files?
what is your processing pipeline?
what transformations are you using to convert your work into QuickTime files?
are you tagging the outputs?
There is not a solution.
Every online service can use a variety of ways too show images. YouTube vs Vimeo vs Chrome vs Quicktime vs VLC vs whatever. Heck, it’s different for iOS than it is for Mac Desktops and likely different for iPad OS.
The only way to do it would be to reverse engineer every conceivable combination of operating system, browser, and service, and make a deliverable for each. It is physically and conceptually implausible. The less honest we are with our clients about this situation the worse we make it for ourselves.
Look at Frame IO on Chrome vs Flame? See how green it is?
Flame does a great job of showing you the raw pixel data. And if it isn’t in Flame, you cannot control how it is shown. Period.
Unless you are looking at the same image on the same screen at the same time in the same room with the clients, anything else is a wash.
I’ll bet that was money well spent . . .
One of our colorists had this issue with things looking different on an executive producer’s ipad when she would get color review files after a session than they had in the bay. eventually we had her bring in the ipad and made a lut that we could apply when making her files to get it to look the way she had expected. We of course from that point on had to run two separate sets of review files after every session, one for her ipad and one for everyone else ![]()
