Default Write Node Compression
you mean the other way around right? I would love to have my write nodes come out as DWAB , maybe time for another feature request let me fix that
EDIT … I have allready put that in 7 month ago. FI-03232
Autodesk Feedback Community this also has my OLD script in it where you just paste a directory path into it and it will change all your writenodes to dwab
here is the right part in the stone+wire.cfg to change this is not the same as the Legacy EXR changing stuff, but it will NOT fix your published write nodes
if you cant find it for whatever reason (maybe because older version installed first?!
should just be able to add OpenEXRCompression=DWAB i guess?
this will give you this:
if you change it mid project you need to pick something else , change project then go back to what you want btw.
That’s it… aaaaaand undocumented aaaaand missing from my sw config templates. Worked a treat getting the project setup correct.
Now just need to see if that applies to write nodes…
strings /opt/Autodesk/.flamefamily_2025.2.1/bin/flame | grep "^DL_" | sort
DL_PREMIUM_RENDERING
…sounds so fancy. I’ll take premium please.
And it doesn’t. Sniff. Lame.
Upvoted. This seems like something that should just be there.
There once was a feature, and it appears to have been deep-sixed…
I’m unclear as to why.
Onwards…
yea its pretty odd, there could be a big improvement to publishing batches, so we have more controlls, like a comp template we could use on publish , bascially a bunch of nuke studio features…
