EXR compression
Can someone confirm that ZIP1 is the same compression as scanline ?
In the media panel you can select zip scanline, however, when exporting from Batch, there is only scanline.
I’m assuming they are one and the same.
I can’t conform that ZIP1 is scanline
But if you are asking if ZIP scanline and scanline are the same I would say yes.
I only say this because I have been stuck on Flame 2020 for a while now and for me to make the compress button in batch give me what I want. I need to manually code it into the start Application.
What I found was this:
OpenEXR compressions available in. flame are:
  • none
  • RLE
  • ZIP-multiscanline
  • ZIP-scanline
  • PIZ
  • PXR24
  • B44
  • B44A
  • DWAA
  • DWAB
So it seems you can’t have a scanline that isn’t a ZIP also.
Not conclusive proof but after seeing your message sit there for 3days I thought you might appreciate some input :+1:
Yes, much appreciated :smiley:
Hey Paul,
I just delivered a job that spec’d Zip1 and scanline passed QC.
-A
Good to know, thanks Andy.
I know this is an old post but its relevant to my situation, i’m doing some v000 for a job and the requested delivery is EXR ZIP 16 bit scanline. Should i be using the ZIP Multi Scan line option in the export settings for this does anyine know or is Multi scan line something different? TIA
the specs are bad
just go wirh zip1/scanline as thats nuke “native”
Zip-multi is zip-16 in nuke
Thanks Finn, they specifically have requsted Zip 16 so ill go Multi. Thabks for clearing this up for me. M
ah ok well then the specs are correct :smiley: and I just couldnt read
