Disable flow production tracking
Hi,
I enabled flow production tracking in flame 2025.
I don’t need it, I was just tooling around.
Now everytime I launch flame 2025, it asks me to log in to flow production tracking. I just cancel it.
Is there a to disable flow production tracking to the state it was before I enabled it? So that it does not ask me to log in everytime?
Thanks in advance
Happy Sunday everyone
Cheers
The simplest way used to be to disable shotgun/shotgrid/flow in the Setup application:
Thanks @philm
It worked
You can also search for this file:
/opt/Autodesk/flame_<VERSION>/cfg/init.cfg
Historically, at the end of the file was the option to set the value of the plugin to Enabled/Disabled:
# SHOTGUN INTEGRATION
# Controls whether the Shotgun integration should be enabled.
# If enabled, a dialog box will appear for all new projects, prompting the
# the user if they want to connect it with a Shotgun project.
# Syntax: ShotgunPlugin <Enabled|Disabled>
ShotgunPlugin Disabled
