How archive some setup and clips?
Do you use a batch based workflow or batchFX based workflow? If you use batchFX then it’s just a matter of archiving the clips you are interested in. The setups associated with the segments in the clip will be automatically archived as well.
If you use a batch oriented workflow, you need to archive your batch reels.
Or you can archive a whole project. But that’s usually overkill.
To archive a clip, go to the media panel, select Archives from the top of the file manager, create a new archive and drop in the clips you require.
I am guessing you are new to Flame, so I would strongly suggest watching the Flame Learning Channel on youtube.
Thank you!. (No i am not new to Flame, but i have been always working with assistants!!!
