Anyone having issues with ML time warp not being repeatable? I’m trying to replace a clip with a new grade/same duration/etc and the tw isn’t the same. Tried saving and reapplying, tried relinking…no luck. Software bug I assume. Let me know if anyone is dealing with this. Im running 2026.2.
That’s the thing with ML processes. They are not reproducible.
Thanks Sinan. I figured that to be the case.
You can probably get it closer if you do a color correction on the footage to match the previous pass. Do something that’s easily reversible, like a color transform. Good luck!
That is indeed the case with many tools, but there are exceptions. Most inference operations use a seed that is randomly picked every time. If your tools allows you to change to a fixed seed the results will generally be repeatable. Not sure if they 100% pixel for pixel value, but if not, then darn close.
