Need Help Setting up HDR project on Flame 2026.2
Your comment has no context at all. We were on the latest version of 2023 but skipped 2024 due to how busy we were. We then tried the 2nd or 3rd iteration of 2025 but ran into the gamma shift issue and had to revert back.
We have literally had zooms with Autodesk about it and sent files, breakdowns etc. They took aaaages to recognise the issue. If trim passes are causing gamma shifts that’s quite a massivly important bug to fix.
The issue is part of my backlog and I can tell you it is sadly not a simple fix.
As my Support colleague told you, we will have a look at this problem in the near future but no ETA for a fix so you will need to stick with the version where the issue is not visible.
