Hey all,
Does anyone know if it’s possible to change the naming pattern for a batchgroup? We have a standard name setup [batch name] __comp__v[iteration###] but I’m working on some scripts that use Python to create the base batchgroup but based per task (i.e. comp, clean-up, matte).
I’ve managed to get everything working just fine with the proper names and all but now our default naming is getting in the way. So for cleanup and mattes I get: 0010__cleanup__comp__v001 which makes sense. I’d rather not change the default naming for various reasons so is there anyway to overwrite this?
Cheers!
Hey Kyle,
there is a hook for setting up the default name:
def batch_default_iteration_name(project, *args, **kwargs):
return "<batch name>_comp_v<iteration###>"
But I think you can’t change that dynamically. It only runs on startup to overwrite the preferences.
How do you create the batch files so they get this naming? I would assume you could change their name to your needs after the creation…
Cheers,
Claus
Hey Claus,
Yeah, that’s what I use to define the default name currently. This new method names the batch based on clip name + task unless it’s a comp since that’s usually what things are. I suppose I’m making it difficult on myself trying to keep the default name but overwrite only in certain senarios.
I’ll try seeing if I can adjust the default iteration name dynamically…might work…
Thanks!
Yeah, no luck @claussteinmassl . You’re right that it seems to only be called when the project is loaded.
I did a quick test. After you created the batch group, you can access the current iteration and change it’s name:
import flame
batch_group = flame.batch.create_batch_group(name="foo")
cur_iteration = batch_group.current_iteration
cur_iteration.name = "<batch name>_bar_v<iteration###>"
Maybe we can also call the hook to find out which pattern has been defined, so the above code respects that naming pattern and only changes “comp” to something else…
Oh man, nice one! I didn’t realize you could change the iteration name like that. That worked perfectly, thank you so much.
For our current use I wouldn’t need to check the pattern since anything but a comp is an exception so I can simply add this little nugget of goodness into that case.
Finally I can have our Flame comp names match Nuke. Yay for a clean workflow and uniformity!
Many thanks again!
