Python Gurus -
I have a script with a function that executes on the post_export_sequence hook. I only want to execute this function if this specific script is run, not every time the hook is triggered. Is there a way to do that?
I’m learning python via flame so I don’t know all of the ins and outs of the bigger world of python.
Thanks!
You can pass a dictionary with custom data between the hooks. You could fill this with something like
„trigger“ => __file__
and react only if your desired script is calling.
I’m not in front the box right now, but can post an example later if that helps.
@bryanb @claussteinmassl Claus was referring to the “userData” parameter in the export hooks.
You can pass a dict as the value and put in custom dictionary entries to communicate to the other hooks in the chain.
