QNap permissions on Rocky 8
Hey guys, a bit OT.
I just bought a QNap Nas, I’ve got it connected to 2 macs and my rocky 8 flame.
Everything is working great on the macs, except on the Linux box it will only give me read permissions
Has anyone here ran into this problem?
have you provided Read & Write access in /etc/fstab?
Identity management can be a royal pain, but since you bought a NAS that can run an LDAP server you can make things relatively straightforward for yourself:
QNAP LDAP server
Configure a user/group that you can use for your macs and your linux workstation.
All of the computers will authenticate against this server and permissions problems will diminish or disappear.
This is a rabbit hole worth investigating.
You will benefit from the time spent.
Hey here is the line in my fstab.
//192.168.1.49/sandbox /Volumes/sandbox cifs credentials=/DL/password,iocharset=utf8,file_mode=0777,dir_mode=0777,noperm 0 0
under “credentials” I created a file named password, which simply states.
“username=username
password: password”
I also use a QNAP NAS and this is my /etc/fstab line based on your data:
//192.168.1.49/sandbox /Volumes/sandbox cifs credentials=/DL/password,file mode =0777,dir mode=0777 0 0
I can read & write from macOS and Linux without any issue. I have opened full permissions for the mountpoints and use local users so very vanilla configuration.
The credential file seems to have a typo: it should be:
username=username
password=password
Unless you made a typo when writing your message then this could be the issue. I would try this first before changing your line in /etc/fstab.
Let us know!
Yup. My fault it was a typo while I was writing it.
Too many fingers :wink:
