Rec709 to ACEScg AI/ML/inference detail/bit depth recreation
It’s primarily a comfort thing, and in the case of Flame also a function of many old color tools sticking around that predate ACEScg. If you use a tool that was designed for log footage on a linear color space it will be harder than it has to be.
Do consider that Baselight’s primary operator ‘Basegrade’ actually converts all color to linear internal and then back. So you can only work in linear. The Baselight ‘X-Grade’ operator does something similar for color, converting to a proprietary Lab style color space for similar reasons. As does the HDR tool in Resolve.
One big advantage of doing color in linear with appropriate operators is that you can shift the entire image up and down in f-stops, and even have a scale for it. The toe doesn’t necessarily get stuck at the bottom either. If you watch it on the scopes, you can see the entire image shifting up and down intact, you can stretch with contrast per channel or in whole. It actually can make multiple color operations a lot simpler and easier to visualize on scopes. Having a functional f-stop scale would even allow you to dial in accepted contrast ratios such as 3:1 (male portraits, business) if you want to get fancy.
In the end it’s what you know and are used to, and also how the tools have evolved. Flame color is great, but also mysterious in ways.
Your Flame experience will vary based on whether you use Color Corrector or Mastergrade, or yet other options.
Log color transforms the constantly doubling values of linear (each stop being 2x the last) into even amounts. Gain, Gamma, Offset, Curves, etc… all work the same across the range of the image, whereas in linear an offset of 0.1 will do nothing to your highlights but push your shadows up into the midtones, and adjusting the curve handles in the shadows feels like grabbing an electrical wire. :smiley:
If you’re using perceptual tools (MasterGrade for example) this isn’t as much of an issue, but it’s a big deal for numbers-based tools like the ole Colo(u)r Correct.
Hence the decree. If you’re not having issues keep on keeping on. There’s no actual rules in Flame. Hahaha.
Greatly appreciate the responses. As usual, both very insightful. Thank you!
I think your setup has this node that is discontinued so you will have to hunt it down like I am doing at the moment… if anyone has it I would greatly appreciate a pointer from where to download it.
@jordibares
Thank you so much Randy, I owe you a beer. :slight_smile:
