A more accurate demo would be to see how they work in an actual comp. I’d be interested in seeing what exists in the dark areas of the “bad” matte. What does it look like with the gamma cranked. I find that often those mattes that show off “great” hair detail also show off miserable edges in a comp.
The SammieRoto matte is better in all ways. The Automatte is garbage.
Then don’t use Automatte. Learn to use different tools for different jobs.
It’s like putting out fires with gasoline…![]()
Nice demo, brah.
im not sure I’m following. hopefully in the sequel “Breakin Mattes 2: Electric Boogaloo” it will be revealed.
I just wish he would zoom out further, so that not a single person can see what he is talking about.
But veterans here can infer. And I agree on the points, however clumsily made.
Could you post it in SD next time pls, and use JPEG-2000?
I didn’t have a problem with the first video, but just for my curiosity, those hair strands look nice on the image to the left. Can you show or explain what is the nature of the color image, what was the background like? Is this green screen, person against a blue clear sky with contrast or was this super busy background with patterns similar to hair etc. What is the pre-requsite to extract such fine hair details with this tool? I’ve tried most similar tools but I haven’t played with the sammie roto 2 (git hub). So just curious.
Nicely done, brah. Sammi looks incredible…
Hey @ALan great results with Sammie. If you can share can you talk about your settings for those Sammie results? Are you using matanyone2 or videomama?
The background is a forest of trees with leaves. Very complex.
Single click VideoMama.
I see. Thanks. I’ll have to explore it myself.
Alan, what box are you running Sammie on? Windows, mac or linux? If the latter, does it play nicely on a Flame box?
It runs on anything in a venv. It’s in all of my playbooks.
Paul - search the forums for Matanyone / Sammiroto / Sammieroto and you can have this up and running in no time.
The new 2.3.5a version vastly simplifies install too.
Yeah sure, I downloaded and I cannot even find the file README is pointing to…![]()
- Execute the following command:
bash install_dependencies.shthen follow the prompt.
