In batch is there any way to set the render range to custom, rather than setup, as default?
No. The one thing you can do is:
- Add a Write File node
- Switch to Custom
- Add it to your User Bin
- Add every new Write File from the User bin (or even better from the Search… widget)
Can we please add this as a preference then.
You can submit a request for it at flamefeedback.autodesk.com
