2027 stabiliser
Using the stabiliser in a 2d transform node, result is showing as black, bug?
what version?? I am 2027.1 and not for me - just used it - so I would say not a bug - check all the silly basics like color transforms / viewer in bypass… uhm is it plugged in?? relaunch flame??
I’m in a different project now, but on 2027.1 and it’s working! I’ll check back in the other project and see what gives. Must be finger trouble!
Ok, still get black. The only difference between these 2 projects is this one is an ex 2025 project archive, (4042x2160, aces), the other one is a newly created project, (HD, REC)
Same procedure, go into the 2d transform node, enter the stabiliser, do my track, then toggle between front and result
I just created a new project, same specs and it works.
