AAF issues in 2027.1
Any one else having issues with aafs? I have several with lots of mixed timecode and the shots that are not 23.98 are all over the place. It’s useless and of course EDLs won’t load with mixed code. I’m spending untold hours manually fixing things. Also, some raw shots are being identified as having the wrong frame rate. Flame sees 30 fps 0n random shots as 23.98. Transcode the raw and flame sees the timecode correctly.
EDIT: I tested it in 2026.2.2 and all is well. Something got fucked up in 2027
EDIT again: A support case has been opened. Case 26270288
I’ve noticed AAF files from recent AVID turnovers are taking a LONG TIME to read in Flame 2025. I haven’t had the time yet to sit with an AVID editor and figure out what has changed. I would estimate it’s 2-3X longer for Flame to read the AAF.
I’m specifically describing long form conforms.
I think it might depend on how you load them. Loading via the Import button takes longer than drag-and-drop. Since I consider anything above 60 seconds to be long-form, I don’t have a true comparison to offer.
Looks like it was an 1d10T error, also known as PEBSAK. Indeed I had a bad aaf, but it was the aaf, not the flame.
