Accurate XML repos from Premiere into Flame, Fixed by Python
That did it! Thanks, @john-geehreng! Sorry…I am newish at conforming from Premiere and this thread is giant. Much appreciated!
I made two little tweaks to the script and uploaded the new version to the portal.
  1. The script won’t fail anymore if it’s not able to sanitize names. It will just print an error message in the terminal and move on.
  2. Fixed the Auto Calculate button. Previously, it could have been giving the wrong value depending on the aspect ratios.
Whoa! Thank you so much. It works. 2023.3
I can’t seem to get script to show up either. Have tried reinstalling many times. Thanks for your help
Hey all! I finally decided I should try this out instead of manually fixing all the conform timing issues from premiere XMLs.
I installed the script from the logik portal with 2025 (and 2024 just to test there too) and I cannot seem to get it to work for me. I haven’t really worked with python scripts in flame so I’m sure I’m doing something wrong.
I did some searching on the forum and from what I understood, I should be able to right click an XML from the media browser and have the option pop up?
give this a shot. if it works for you, i’ll put it in the portal
fix_premiere_xmls.zip (200.4 KB)
thank you!!! give it a try now
That worked. Thank you so much for updating the script!
