ACES blue light artefact fix
Dear all
Do you know if there is an inverse of the ACES blue light artefact fix ctf?
Yes it can be done in a color management node or in the native matchbox.
Any CTF may be inverted by opening it in Custom mode in the Colour Mgmt node.
Keep in mind that the “blue light artifact fix” matrix was superseded several years ago by the ACES Reference Gamut Compression transform. This is available in the default Flame config and may be applied either in Custom mode of the Colour Mgmt node or in the Look node. It may be inverted in either approach.
Great info @doug-walker . Thanks.
Thanks @Ryland too.
