Add system folders via python date syntax
Hello,
I’d like to be able to change the python script in the add systems folders from dashes to underscores
for example YYYY_MM_DD instead of the default YYYY-MM-DD
Hey Tyler. If you do a Find and Replace using %Y-%m-%d and %Y_%m_%d that should do the trick.
thanks john, i’ll give that a go!
