Adding %Y%M%D to today string?
Hey hey…so, I’m trying Python and attempting to modify @john-geehreng 's Dated Time and Folder Script to change the format of the date to use within my ecosystem.
cript Name: add_dated_and_timed_folders
Script Version: 1.0
Flame Version: 2021.2
Written by: John Geehreng
Creation Date: 12.14.20
Update Date: 12.14.20
Description: This will create system folders in the media hub. The format will be 2020-12-14/1400.
I was attempting to modify the:
today = str(date.today())
…by adding an argument, like this…
today = str(date.today(%Y%M%D))
…to create a 20210128 format but Im getting an error in the shell about the the string not being able to take arguments.
If that string can’t take arguments, should I use a different technique?
Thanks!
r
This might not be the “right” way to do it, but I think it will work for you if you just want to remove the "-"s.
date = str(date.today())
today = date.replace("-","")
Here’s a good article:
look at the strftime command.
import datetime
x = datetime.datetime(2018, 9, 15)
print(x.strftime("%b %d %Y %H:%M:%S"))
