While I’m inclined to always max out a computer, I will note that I’ve been running Flame on an M1 laptop with 64 gigs of memory and it’s been a perfectly fine experience. I keep waiting for a reason to upgrade to a studio, but it’s yet to land, and the laptop keeps doing amazing work.
I’ve got a little 4-slot thunderbolt 3 NVME raid that I use as a cache, but I hear you on the internal storage. I think with whatever my upgrade will be, I’ll have the cache local and just sync necessary files over to one of my raids as a backup. The local drives on macs are insanely fast.
I would max out the ram over anything else. I do believe there is the M5 ultra coming out in a month or two. if you can wait that is. I use OWC thunder blades X12s and they are great. if I were you id get two. if you can two of the OWC. envoys - 8TB if you can. Separate the cache from the project files. you could get away with a couple of 4s maybe. I went for a 1TB internal (apple SSDs are super expensive) and m3 ultra Total Number of Cores: 32 (24 Performance and 8 Efficiency) and Memory: 256 GB. works a treat!
Ooh M5 Ultra… probably worth waiting for that I’d say.
Yeah 256GB Ram seems a top priority.
Aren’t the Thunderblade x12s like £3,000+ each. I think (I hope!) that’s overkill and way too expensive for me.
Good advice on the separate cache. I was wondering about that.
An external cheaper option might be better than Apple’s 4TB internal maybe? But £1,000 for 4TB isn’t bad compared with the OWC options.
I am wondering about the
28 core CPU, 60 core GPU
vs
32 core CPU, 80 core GPU. Has anyone had any experience on how different more cores feel?
I’ve seen reporting but haven’t looked closely since i’m not in the market for new system - with the memory shortages, several high-end models are out of stock. Check that out before getting too set on a config.
I got the nod that data centres are using up all the NVMEs. so I got two X12s and a bunch of Envoys at the old prices. now they’ve gone up by 25% I think. Main thing with the Mac studio is to get the Ultra as the double silicons is where all the speed is gained. I think the amount of cores will be less noticeable.
only thing about the internal storage and the envoys is that they are single disks - so you cant raid them. I used to use the thunderblade X8s as a stupid single drive and twice I have them fail in two years. but it did get me into the habit of backing up every night to an older HDD raid. I run the X12s as raids.
If possible I’d avoid using the system disk as framestore and for uncached/internal storage for that matter for various reasons including overall flame’ performance. Cheap but robust and reliable external NVMEs from OWC (even a single NVME) will do more than fine for a makeshift framestore (event as permanent framestore for needs of some) these days, something unthinkable just a few years ago.
Refurbished is a great way to go with Mac. Over the years I’ve purchased a few refurbished units directly from apple and with all the QC checks and care thats taken before they are shipped, they are practically new machines in non-printed, plain boxes with reduced pricing.
Apple hardware in general is quite robust, is able to take abuse, and usually lasts for years before anything physically dies or breaks down inside their machines. So even if you are purchasing a refurbished Mac from a reseller and not directly from apple, in theory you should be good. OWC has been good for me for refurbished apple stuff.
