Animating text
Hello friends. I’m on an animating text adventure. I want to animate character by character a line of text. I found a preset that comes very close but I can’t work out how to tweak it to the reference supplied to me from client.
Here’s the ref
So in simple terms I want each letter to zoom and fade in on its’ spot character by character. I can do the blur and reveal with y_lensblur and masking
The closest presets I found to modify were the “behind camera 3d” and “fade in”
With the “3d behind camera” preset I managed to get this far but cannot work out how to put the centre point on each character.
Any help appreciated.
Many thanks
Less than 3 minutes in After Effects.
https://www.google.com/search?q=after+effects+lettwrs+fade+on+and+scale+on&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari#kpvalbx=_Lsz7ZKOcCb3GkPIPjveOwAM_73
Thanks Randy but I want a Flame solution
Here you go John
Archive.zip (15.7 KB)
Thats perfect! I owe you a beer! Thank you so much. Now to understand how that works. :slight_smile:
Open the two animated channels: scale and transparency and play with the length, position, reverse, etc of those 2 channels. And the time offset.
Thanks. Did you make it from scratch or pick a preset and modify it?
From scratch, I have a hard time understanding how to customise the presets.
If you need help getting a closer result give me a shout. I have some time to tweak it!
Thanks for the offer. I’ve got it where it needs to be for now. It’s a shame that you can’t blur 3d text in action. I’m using y_lenseblur post animation to do that and it’s working well.
