Batch Node Bin filtering
I know I had this issue before but I can’t seem to remember how to fix it, issue is if I press a key over the tools in batch they don’t highlight but pop and then go back to like I didn’t press any hotkey over them, usually the a tools would stay selected, another issue is if I alt tab to a shell it automatically pops back to flame. I have the dlus smoke English layout selected in keyboard and I can’t figure it out , thanks
It’s a bug I believe. If you hide the library when in batch it should behave when selecting nodes as expected. I think it’s been fixed in 2022 but I haven’t gone to that version yet.
yes that was totally it, I completely forgot about that bug since it hasn’t happened in a while. Thank you!!
@KuleshovEffect
Just putting this down since I just remembered it, if you switch your library from list to proxy view that also resets the bug.
Or you can stay in List View, but turn off thumbnails.
This bug has just come up again on one of our Flames running 2023.3.
Have reported it to Autodesk and for now those workarounds are good :+1:
Thanks Logik friends :hugs:
