I created an animated slideshow from single shots (~ 100), setting a still duration (00:00:02+08)
during the import in MediaHub. Up until now, it has been a “Timeline-only” project
(with the following Timeline FX: TW, 2D Transform, Text, Resize-FX).
I was hesitant to learn node-based compositing in Batch because the project is mostly shot-based, and I felt the timeline was better for keeping an overview without getting lost in nodes
My question:
Can all the effects for the magazine covers (TIFF) floating in the foreground over a scanned map (TIFF) in the background be composited in the Timeline, and maybe in Effects, or is Batch or Batch FX better suited for this?
Thank you in advance!
Pls see:
Photos-und-Magazine-Covers-floating-over-ElCapitan-Topos.mkv
From 01:34 till 01:47
This is a perfect project to jump into batch/action compositing. It doesn’t have to be a huge setup either. Add all the single images as different media to an action node. Place them in space and move your camera.
When adding your still frame layers to the media list in Action, be sure to Lock the media layer (to frame 1, or whatever since it’s a still). This should speed up the interactivity and the render speeds, as Flame will not be reading the media for each layer for each frame of the comp, but rather will keep just the locked stills in RAM. If I’m describing it right…
*With that many still frame media layers, it’d be interesting to know what kind of performance increase is achieved after locking the layers…
