Bookmarks 2025
Literally no idea what I did in re-writing this, but this is working now:
def get_main_menu_custom_ui_actions():
def create_project_bookmark(selection):
    import os
    import json
    import flame
    try:
        from PySide6.QtWidgets import QInputDialog, QLineEdit
    except ImportError:
        from PySide2.QtWidgets import QInputDialog, QLineEdit
    # BOOKMARK NAME
    bookmark_name, ok = QInputDialog.getText(
        None,
        "Create Bookmark",
        "Enter short bookmark name:",
        QLineEdit.Normal,
    if not ok or not bookmark_name.strip():
        return
    bookmark_name = bookmark_name.strip()
    # BOOKMARK PATH
    bookmark_path, ok = QInputDialog.getText(
        None,
        "Create Bookmark",
        "Enter full file path:",
        QLineEdit.Normal,
    if not ok or not bookmark_path.strip():
        return
    bookmark_path = bookmark_path.strip()
    # CURRENT PROJECT
    project_name = flame.project.current_project.project_name
    bookmarks_file = (
        "/var/opt/Autodesk/flame/projects/{}/setups/status/cf_bookmarks.json"
        .format(project_name)
    if not os.path.exists(bookmarks_file):
        flame.messages.show_in_dialog(
            "Error",
            "Could not find:\n{}".format(bookmarks_file),
            "error",
            ["OK"]
        return
    # LOAD JSON
    with open(bookmarks_file, "r") as f:
        data = json.load(f)
    sections = data.get("DlBookmark", {}).get("Sections", [])
    # FIND PROJECTS SECTION
    project_section = None
    for section in sections:
        if section.get("Section") == "Project":
            project_section = section
            break
    if project_section is None:
            "Error",
            "Project section not found.",
            "error",
            ["OK"]
        return
    # ADD TO BOOKMARKS ARRAY
    bookmarks = project_section.get("Bookmarks")
    if bookmarks is None:
        bookmarks = []
        project_section["Bookmarks"] = bookmarks
    bookmarks.append({
        "Bookmark": bookmark_name,
        "Path": bookmark_path,
        "Visibility": "Global"
    # SAVE JSON
    with open(bookmarks_file, "w") as f:
        json.dump(data, f, indent=4)
    # MESSAGE
        "Bookmark Created",
        "Bookmark: {}\nPath:\n{}".format(
            bookmark_name,
            bookmark_path
        "info",
        ["OK"]
return [
        "name": "BOOKMARK TOOLS",
        "actions": [
                "name": "Create Project Bookmark",
                "caption": "Create Project Bookmark",
                "execute": create_project_bookmark,
