Hi, does anyone know any good change detection software that would work with Flame?
Similar to Cargo Cult’s Matchbox, so it would compare two video files or two sequences
We have a wild recut situation to unpick, so any ideas much appreciated
Thanks!
If you just need a change analysis/list rather than automation to reconcile everything, you could use Cargo Cult software.
Export an AAF and render of the before and after and feed it into Matchbox. It will do the analysis and give you the results you can then work through.
If you check their YT channel, there are several videos on how to use it for VFX.
I use it from time to time for sound, but haven’t used it on a Flame timeline, though I don’t see any reason why it shouldn’t work.
Thank you, I believe we have this somewhere so will give it a try
Resolve has a built in timeline compare mode thats pretty great too
