Thanks @hBomb42
Ill try this out
ytf
December 26, 2024, 2:57pm
23
allklier:
…active, it has a floating window which reads out values and can keep a palette. You can switch the read out between the different formats (hex, 8bit, 16fp, etc.)It’s not as fancy as the pixel analyzer in nuke with medians, etc. but it has all the basics.if you wanted to white balance with that, switch the master grade gain to RGB sliders, and then manipulate until all three values are roughly equal.
You can also set the sampler to 8bit. I find that the simple 3 digit numbers are easier to comprehend at a glance. Doing this does not change the bit depth of the image.
george
December 28, 2024, 9:52pm
24
Is this a reversable node ? I dont have access at the moment to check things out
