Conform: Keep Shot Names
Hi @knhn - can you explain the bulk edit thing?
You can edit all the shot names for the open sequence in the Conform tab.
  1. open the sequence
  2. go to conform tab
  3. make sure Hide Linked is turned off
  4. shift + select all the rows/segments you want to edit
  5. 2x tap in the Shot Name column (not the header, but in the column of entries)
It will change the names to an editable field that has sequential notation if it can detect it. So if your segs are
ABC_sh001_scanlinear_v1
ABC_sh002_scanlinear_v1
ABC_sh003_scanlinear_v1
the column will change and show
ABC_sh00*_scanlinear_v1
It collapsed the number sequence to the asterisk. Then just delete the _scenelinear_v1 and mash enter and it will change all of those shot names but keep the sequential part it detected.
Peek 2023-01-11 13-08
You might have to download this GIF and then open it in separate browser tab to see it full size.
That’s fucking special. Thanks!
This is such a good find :+1:
