Copy TC to clipboard
Ok, so I used Python scripts to copy the current TC: copy_tc_information (Frédéric Warren) and sg_TC_to_Clipboard_in Sequence / sg_TC_to_Clipboard_in_MediaPanel (Stefan Gaillot). They don’t work anymore on 22.2. Isn’t it crazy to need a python script for such a trivial thing? Are they updated versions that I am unaware of? Thank you!!!
Did they work in 2021.x for you, but now don’t work in 2022 and beyond? If so, Flame 2022 requires Python 3 ish and most of the scripts were updated to reflect these changes…perhaps yours have yet to be updated to the Python 3 flavor?
There’s one in the Logik Portal, too.
I don’t see it on the Logik Portal, how is it called? Do you mean clip info? It doesn’t do the same thing… Thanks!
Yes, that’s the one I was thinking of.
If you want, send me the scripts and I’ll see if I can get them working in 2022.
Mike
That would be amazing Mike! Let me know if you can download those: iCloud
Thank you so much!
@MikeV You are a friggin’ leg end.
Appreciate your generosity and time to the group :love_you_gesture:
I just added timecode_to_clipboard to the Logik Portal/Github. I took both of Stefan’s scripts and combined them into one. I also updated it to work in 2022. It was just a matter of updating the print command.
I didn’t updated Fred’s script since it seems to do the same thing as Stefan’s.
Mike
Thank you so much, Mike! It is fantastic!
Anyone use this Franck Lambertz script? I converted it to python 3 but after I did the update to Flame 2022.2 it stopped working. The idea it’s the same but the information is displayed in a window.
Flame 2022.1 its ok.
Flame 2022.2 with Error.:
FrameInfo execute callback [<function get_timeline_custom_ui_actions.<locals>.fl_frameInfo at 0x7fa687e67170>((<flame.PySegment object at 0x7fa687e66d50>,),)] failed because of an error of type "'<' not supported between instances of 'PyTime' and 'PyTime'"
Any suggestion @MikeV ?
Can you post the code with the changes you made?
I will post you the update tonight.
F
Nice, thanks @lambertz .
Merci Franck! @lambertz :wink:
This one works for me in 2022.2. Let me know.
(I need to check how to publish to the logik portal ;( )
F
FL_Frame_info.py (3.6 KB)
Perfect, it’s very useful. Thanks @lambertz
Cool, I pushed it to the logik portal. Let’s see when it will be added to the main list
F
Any chance that this script is an easy fix to update for 2025? I like the option to be able to copy the TC from a clip on the desktop and from the play head in the timeline.
2025 python
