Logik Portal Updates
Hi everyone. For anyone interested and not on Discord I’m going to post here when there are new scripts/updates to scripts on the Logik Portal. I’ll start it off with some new scripts from @borzi and @knhn.
New Python Scripts
Node Ops - Align Nodes Nudge
Nudge selected nodes in Batch using the up, down, left and right arrow keys.
Copy Clip Filepath To Clipboard v1.2.0
Copy the filepaths of the segments contained within the selected clips or sequences.
Updated Python Scripts
Go To Frame Number v3.0.1
Filter Selection v2.1.1
Set In Out Marks v3.0.1
Find Replace In Name Advance v3.1.0
Batch Nodes v3.10.0
  • Updated to PyFlameLib v4.3.0.
  • Fixed misc bugs.
Delete Folders v2.9.0
Encompass Selected Nodes v2.7.0
  • Added menu to set compass color.
Color Segment Fx v1.3.0
  • Added “No Color” option to color menu and removed “Remove Color” button.
Import Camera v4.1.0
Add Mux v2.5.0
Create Projection v2.9.0
Delete Iterations v1.5.0
Add Dated And Timed Folders v2.3.0
Add Gmask v2.8.0
Shot Sheet Maker v3.12.0
Axis To Point Locators v1.5.0
Flush Renders v1.2.0
Multi Batch Render v4.12.0
Import St Map v3.0.0
  • Batch setups are now created with either matchbox or Flame ST Map nodes. Flame ST Map nodes are only available in Flame 2025+.
Reveal Path v2.8.0
  • Fixed Bug: Revealing clip in MediaHub was not working.
Fill Gaps v1.3.0
python update all scripts would be a great addition
New Inference Node
BiRefNet_HR-general-epoch_130
Bilateral Reference for High-Resolution Dichotomous Image Segmentation (Matte Extraction) (Flame 2026 Only!)
New Python Script
Uber Slate Maker
Create/Update slates with new Type Node from CSV’s in Flame 2026.
Replaces old Slate Maker script.
User Batch Setups v1.7.0
Delete Empty Folders v1.4.0
Uber Save v4.9.0
Clip To Batch Group v2.7.0
Create Shot Folders v5.3.0
Import Browser v2.5.0
Invert Axis v2.9.0
Set In And Out Plus One Frame v1.3.0
New Matchbox
ak_slice
Slice Tool - image eval
New Python Script
Find Replace In Type v1.0.0
This script will find a specified search string within a Type TimelineFX and
replace that search term with something else without having to enter the Type
editor. Works on segments or sequences containing Type TimelineFX. For sequences, it will
find all segments that have Type TimelineFX and perform the find - replace.
Create Media Panel Templates v3.8.0
Folders To File System v1.5.0
Export Frame v2.5.0
Import Write Node v2.10.0
Adjust Text Fx v2.10.0
Neat Freak v1.9.0
  • Works with Neat v6.x.
  • Added check for Neat OFX plugin. If not found, show error message and return.
Rename Shots v1.10.0
Master Builder v1.5.0
  • Added support for PyFlameTabWidget.
Srt To Xml v3.7.0
Replace Render Nodes v2.2.0
  • Updated to PyFlameLib 4.3.0.
Refresh Python Hooks v1.8.0
  • Added menu to refresh python hooks from timeline.
Logik Portal v6.5.0
Path Translator v2.1.0
Batch Nodes v3.11.0
  • Updated to PyFlameLib v5.0.0.
  • Bug fixes to batch nodes menu.
  • Window layer order in linux is now fixed.
Create Export Menus v5.4.0
Color Segment Fx v1.4.0
  • Escape key closes main window.
Add Dated And Timed Folders v2.4.0
  • Escape key closes setup window.
  • Time is now always given as four digits.
Create Shot Folders v5.4.0
  • Escape key closes out of windows.
  • Fixed: Reveal in Finder button was not disabled when File System Folders button was unchecked.
Shot Sheet Maker v3.13.0
  • Images are linked to cells when opening shot sheet in Excel.
  • Option to save images to shot sheet export path.
  • The tab key can now be used to cycle through all the entries in the Edit Column Names window.
Clip Path To Clipboard v2.5.0
  • Path now includes the file name.
Auto Scale Xmls v1.0.0
  • use flame.projects.current_project.project_folder to determine where to save json"s and action"s
Scale Compensator v1.1.1
Build Resolution List v1.0.0
New Python Scripts
PDF to JPG v1.0.0
  • Quickly export a pdf as jpgs from Flame.
CMYK to RGB v1.0.0
  • Convert CMYK images that Flame can’t read into RGB format.
Logik Portal v7.0.1
  • Fixed window sizing issue.
New Python Script
Nano Banana v1.0.0
  • Integration for Nano Banana in Flame
Build Resolution List 2.0.0
  • Fix v1 and how it wasn’t really using flame.projects.current_project.project_folder to determine where to save json’s,
Fix Premiete XMLs 3.0.0
  • Updated for pyflame lib v5.2.3
Scale Compensator v2.0.0
Sequence Renamer v2.1.0
  • Added sequence mode to mediahub after renaming.
Social Versions v1.0.3
  • Updated version for pyflame lib v5.2.3
Website Update!
pyflame.com is no more. logik-portal.com is the place to go for anything related to the Logik Portal.
:puzzle_piece: New Inference Node: CorridorKey v1.0
Model: CorridorKey_v1
Flame Version: 2026.2
Description: Green-screen matting model using GreenFormer vision transformer with Hiera encoder. Takes RGB front plate + alpha-hint matte input → outputs refined foreground RGB and alpha
matte. Fixed resolution 2048×2048. ImageNet normalization baked in.
Converted to ONNX from the original PTH model.
:link: GitHub - nikopueringer/CorridorKey: Perfect Green Screen Keys · GitHub
Nano Banana v1.1.0
  • Added Gemini Chat button to send a message to chat with Gemini about creating an image.
  • Updated model menus to clarify model names.
  • Now works with Flame 2025+
Nano Banana v1.1.1
  • Fixed export preset path. This was causing the script not to work when running the script with an image selected.
Logik Portal v7.1.0
  • Submit buttons now redirect to logik-portal.com for submissions.,
  • All files are now downloaded from logik-portal.com. FTP server is no longer used.,
  • Increased window size.,
  • Downloads are now much faster.,
  • Updated to PyFlameLib v5.3.1.
Clip to Batch Group v3.0.0
  • Updated to work in Flame 2027.
  • Added setup window to configure script options.
  • Set batch group to use either Render or Write File node.
  • Set batch group suffix.
  • Ability to set a tokenized save path. Batch setup will be saved when the batch group is created.
Reveal Path v2.10.0
  • Added ability to reveal shot folder for batch group in Finder and MediaHub.,
Neat Freak 2.2.0
  • Updated to work in Flame 2027+
  • Added option to save/use Neat node profiles
  • Added ability to add Neat OFX to selected timeline segments
  • Fixed: Bug causing multiple Neat reels to be created in a batch group
New Python Script
CSV Renamer v1.0.0
Rename selected clips and sequences using names chosen from a CSV file.
Create Export Menus v5.5.0
  • Added Import Export button. When checked, exported clip will be imported back into Flame. Only works with Movie preset types.
New Python Script
Batch Group to Shot Folders v1.0.0
    Copy or Move selected batch groups to folders in the Media Panel using a tokenized path.
    View on Logik Portal
