Hello
I played around with keyframes and now there is a cut(?) in the Audio track which I cannot remove. Even the audio track is removed and the sound file is imported again (drag/drop) from the media panel.
How can it be removed?
Thank’s a lot!
If you’re keeping the track on the right, you can just delete the track on the left and pull the head of the remaining track to the left. Or visa versa. Or am I missing something?
Whilst parked in a “cut” in a segment, I think it’s Control + Delete keys in Smoke Hotkeys to “remove a cut in a segment.”
Thank’s it does work as you described. I used the Trim tool for that:)
