Flame Feedback requests implemented in Flame 2026
Hello Everyone,
Here’s the list of requests submitted at flamefeedback.autodesk.com that have been implemented in Flame 2026. Thanks to everyone taking the time to add requests and vote.
FI-00040 Text: Give visual feedback on which font is missing
FI-00208 Preferences: Set a default project template to be used for every new projects
FI-00282 Text: Make Batch Context views available in the Text node
FI-00739 Support for Blackmagic Davinci .cube format
FI-00774 Project Management: Possibility to modify the name of converted projects.
FI-01029 Project Management: Ability to manually create multiple workspaces
FI-01103 Project Management: Show a Warning prompt when creating a “New Workspace”
FI-01163 Load Font: Allow all font files to coexist alphabetically in font browser regardless of case (see description)
FI-01229 Right Click options available in Action Text should be available in Batch Text
FI-01305 Project Management: Ability to delete Workspaces
FI-01611 Text: New Text tool
FI-01904 Timeline FX: Add back the controls for the Text in the Timeline Ribbon
FI-02016 Text: Access to Adobe Creative Cloud fonts
FI-02040 Configuration: Increase the StoneFS partition limit.
FI-02060 Hardware Anti-Aliasing attached to user setting
FI-02070 Resize: Machine Learning Upscale
FI-02105 Project Management: Ability to give a custom name to a Workspace
FI-02151 Project Management: Make the project nickname editable after the project has been created.
FI-02262 New Project Settings from existing project
FI-02587 Batch: Have individual anti aliasing on/off button status for each setup
FI-02611 Text: Add colour management controls to the viewport
FI-02690 Timeline: Ability to copy the file path of a Timeline segment to the Clipboard
FI-02809 Project Management: Update the Window at startup
FI-02866 Text: Seeing all the attributes / styles of a .TTC
FI-03126 Colour Management: Add ACES CLF interoperability
FI-03145 Fix long freezes when gateway not available.
FI-03231 Project Management: Add DWAB compression to OpenEXR’s Cache and Render options
FI-03252 Media Export: Add anti-aliasing/softness control to the Subtitles Burn-In
FI-03261 Disabling WiretapGateway in Project Server workflow
FI-03350 Text: Improve the font selection workflow in the Load Font file browser
FI-03355 Configuration: Better way to handle DTVsync/Freesync
FI-03378 Media Export: Also add OpenEXR’s exr/reelName information into exr/owner
FI-03390 Project Management: Add an indication for the current project in the window opened inside the application
FI-03396 Lens Distortion: Support FOV values from 3D Equalizer
FI-03398 Batch: Use Background Reactor to render a BFX clip.
FI-03423 Python API: Add more Project Management Options
Thank you! I look forward to seeing your list of implemented feedback when the new version is released.
That’s too many. The list is too long!
We wish it would be longer!
Bravo! There are some interesting features under the hood.
Keep up the good work @fredwarren @Slabrie et al. Thanks.
