Flame Feedback requests implemented in Flame 2023
Hello Everyone,
Here’s the list of requests submitted at flamefeedback.autodesk.com that have been implemented in the Flame 2023 release. Thanks to all of you who are using this platform.
FI-00095 - Preferences: Support the Bold Font function on macOS
FI-00557 - Animation: Ability to save Animation channel settings
FI-00663 - Animation: Ability to delete keyframes forward / backward.
FI-00954 - Animation: Shortcut or button to exhibit only coloured channel in animation editor
FI-01026 - Animation: Snap keyframes to frame when resizing a channel from the Timeline
FI-01055 - Animation: Update the Animation Editor
FI-01798 - Python API: Add a Match function to create a PyClip from a PySegment.
FI-01860 - UI: Color manage the interface for HDR
FI-02028 - UI: Ability to minimize Flame from the interface
FI-02036 - Python API: Ability to save a timeline segment to a media panel object.
FI-02102 - Python API: Create Color Source in Timeline
FI-02197 - Python API: Get open / close library status
FI-02227 - Python API: Import Clip Options
FI-02244 - Python API: Ability to copy/paste/cut/duplicate a Timeline segment.
FI-02246 - Python API: Ability to perform editorial operations (‘insert’, ‘replace’, etc.)
FI-02277 - Python API: Get clip from the visible timeline
FI-02294 - Python API: Have control of the Dynamic button in the rename segment.
FI-02339 - Hardware: Apple XDR Display HDR support
FI-02600 - Utilities: S+W that is not dependent on GPU
FI-02611 - Text: Add colour management controls to the viewport
FI-02645 - Hardware Validation: Remove legacy checks
FI-02651 - Installation: Do not change DisableRemoteConnection=True to False when a new version is installed.
FI-02656 - Conform: Default to Project Resolution / Bit Depth / Frame Rate instead of resolution from file
FI-02659 - Python API: PySegment should have PyClip attributes accessible
FI-02713 - Python API: function to update the channel output of a segment
FI-02719 - OS: Use StartupWMClass=flame to prevent multiple instances of Flame from being launched
Somehow I totalled missed that you added this during Beta. Nice!!
@fredwarren
At the bottom of this page:
https://help.autodesk.com/view/FLAME/2023/ENU/?guid=GUID-86AC768A-7BC5-4D7C-9E4A-79CBEF8EDA0B
It says:
Conform—Bit depth and resolution : An XML or AAF file is now imported at its resolution and bit depth instead of using those of the project.
Perhaps that’s a copy error on the website?
It’s my absolute favorite post-release list! :clap:t2::clap:t2:
I love these little “quality of life” improvements :clap:t2::clap:t2::clap:t2:
its in the main menu on the bottom right-- where exit flame and settings etc are
The Ability to minimize Flame from the Flame Menu is only available on Linux.
Ref AAF & XML Conform Sequence attributes:
Sorry this is sadly wrong. Text should say that with 2023 release, AAF & XML are now imported at the resolution and bit depth of the project, which makes more sense since we have discussed this change here some time ago.
