Flame Gate UI
If anyone is interest I just added a new script to the Logik Portal that recreates the Gate UI from Toxik. I was a huge fan of Toxik while it was out and the one thing I’ve always wished Flame had from it was the Gate UI.
For those that have never used it, the Gate UI was a circular pop-up menu that could quickly be brought up with a hotkey and had multiple options that could be picked by quickly swiping over the desired action/tab in the Gate UI.
The way I have it setup now is to just work in Batch. Just hit alt + ~ and it comes up. Actions for the Gate UI tabs can be added in the script setup (Flame Main Menu → Logik → Logik Portal Script Setup → Gate UI Setup.). Any python scripts or batch hotkeys can be added. The number of tabs can also be changed (4 or 8) along with some other options.
One thing to be mindful of is that the cursor can’t tell which part of the Flame UI it’s currently over. So the Gate UI can be opened over the Media Panel and the Batch Node area. When its opened over these areas the actions may not always work if they’re meant to work in Batch. Everything should work when its opened over the Batch Schematic area… so just be mindful of where you open it.
Happy Thanksgiving!
Mike
This is so sick, I loved that in toxic , love it man, thank you
