Interleaved audio export
Hi all,
I have a spec to create a prores export for a film I’m on:
All audio channels need to be on one stream (interleaved) not a stream for each channel and the channel assignment should be the following:
Channel 1 - Left
Channel 2 - Right
Channel 3 - Centre
Channel 4 - LFE
Channel 5 - Left Surround
Channel 6 - Right Surround
I have the audio as individual mono tracks, but cant seem to make a 6 channel interleaved export. any ideas?
tia
Des
Hi Des,
not done this myself, but have you tried settings the Audio options in the Media Export window to Midown:-As Is?
I think this will create the movie file with all the tracks exactly as they are on the timeline, so as long as those are correct…
adam
I do not believe this is possible in flame. @La_Flame ?
I usually get these as a separate delivery from the mix house.
it works with 2, 4 or 8 tracks but no oprtions for 6! grrr
correction, it maintains stereo pairs, but I cant make a 6-channel group.
improvement request logged:
FI-02716
D
Hey Des!
How are you mate?
Did you ever find a solution to this one?
Have exactly the same issue for a screener export…
R
Only way we found is to use Resolve.
Hey Rich,
I’m ok mate, hope you are too, pint soon?
re this issue, never sorted this. :frowning:
my feature requests and improvement suggestions just seem to fade into ancient history …I’m heading in the same direction myself :slight_smile:
D
