Lights
Not sure if theres a new toggle some where, but I seem to have lost the icon for the focal point of a spotlight in 2027.1
You’re sure you are in target mode and not free mode?
Good spot, I was! However, in 2025, you see the icon in free mode.
This was an intentional change based on a request made by @GPM a long time ago.
oh…
Can we get it as an option? I use it all the time
It is there is Target mode. It does not do anything in Free mode…
By the way, if you haven’t seen the update on flamefeedback.autodesk.com, we also added the possibility to show icons in the FrontMatteOffset matchbox shader.
This site can’t be reached
Check if there is a typo in flamefeedback.autodesk.com.
does feedback.autodesk.com work for you?
yes
